DESeq2 experimental design and interpretation
Update. 11/13/17 Thanks to Mike Love for pointing out an error. This is just my understanding. There maybe other errors.
To allow complex study designs in iDEP(http://ge-lab.org/idep/), I tried to understand how factoral models are built and the desired results are extracted from DESeq2. The following is based on the help document from the resutls( ) function in DESeq2, plus some of Mike Love’s answers to questions from users.
An important point I want to make is the interpretation of results is tricky when the study design involve multiple factors. See figure above for an example involving 3 genotypes under 3 conditions. Similar to regression analysis in R, the reference levels for categorical factors forms the foundation of our intereptation. Yet, by default, they are determined alphabetically.
Before runing DESeq2, it is essential to choose appropriate reference levels for each factors. This can be done by the relevel( ) function in R. Reference level is the baseline level of a factor that forms the basis of meaningful comparisons. In a wildtype vs. mutant experiment, “wild-type” is the reference level. In treated vs. untreated, the reference level is obviously untreated. More details in Exmple 3.
iDEP provides a GUI to DESeq2 for most experimental desings. It also provides convienent interface for exploratory data anlysis and pathway analysis. Try it at http://ge-lab.org/idep/
Example 1: two-group comparison
First make some example data.
library(DESeq2)
dds <- makeExampleDESeqDataSet(n=10000,m=6)
assay(dds)[ 1:10,]
##        sample1 sample2 sample3 sample4 sample5 sample6
## gene1        6       4      11       1       2      13
## gene2        9      12      23      13      14      28
## gene3       58     121     173     178     118      97
## gene4        0       4       0       3       8       3
## gene5       27       3       6       9       8      12
## gene6       48       8      35      38      21      13
## gene7       36      50      61      52      44      22
## gene8        6       8      16      14      18      19
## gene9      214     266     419     198     157     166
## gene10      20      12      16      12      16       2
This is a very simple experiment design with two conditions.
colData(dds)
## DataFrame with 6 rows and 1 column
##         condition
##          <factor>
## sample1         A
## sample2         A
## sample3         A
## sample4         B
## sample5         B
## sample6         B
dds <- DESeq(dds)
resultsNames(dds)
## [1] "Intercept"        "condition_B_vs_A"
This shows the results available. Note that by default, R will choose a reference level for factors based on alphabetical order. Here A is the referece level. Fold change is defined as B compaired with A. To change reference levels, try the relevel( ) function.
res <- results(dds, contrast=c("condition","B","A"))
res <- res[order(res$padj),]
library(knitr)
kable(res[1:5,-(3:4)])
baseMean log2FoldChange pvalue padj
gene9056 360.168909 -2.045379 0.0000000 0.0001372
gene3087 43.897516 -2.203303 0.0000173 0.0857004
gene3763 72.409877 -1.834787 0.0000433 0.1434364
gene2054 322.494963 1.537408 0.0000682 0.1692730
gene4617 6.227415 6.125238 0.0002015 0.4001027
If we want to use B as control and define fold change using B as baseline. Then we can do this:
res <- results(dds, contrast=c("condition","A","B"))
ix = which.min(res$padj)
gene9056 360.168909 2.045379 0.0000000 0.0001372
gene3087 43.897516 2.203303 0.0000173 0.0857004
gene3763 72.409877 1.834787 0.0000433 0.1434364
gene2054 322.494963 -1.537408 0.0000682 0.1692730
gene4617 6.227415 -6.125238 0.0002015 0.4001027
As you can see, the fold-change are completely opposite direction. Here we show the most significant gene.
barplot(assay(dds)[ix,],las=2, main=rownames(dds)[ ix  ]  )
#Example 2: Multiple groups Suppose we have three groups A, B, and C.
dds <- makeExampleDESeqDataSet(n=100,m=6)
dds$condition <- factor( c( "A","A","B","B","C","C") )
dds <- DESeq(dds)
res = results(dds, contrast=c("condition","C","A"))
gene2 3.634986 -5.101773 0.0348679 0.5515088
gene20 4.678176 -4.490982 0.0445664 0.5515088
gene34 56.068672 -1.462155 0.0167820 0.5515088
gene35 537.847175 -1.177240 0.0087913 0.5515088
gene41 93.967810 1.064734 0.0412034 0.5515088
Example 3: two conditions, two genotypes, with an interaction term
Here we have two genotypes, wild-type (WT), and mutant (MU). Two conditions, control (Ctrl) and treated (Trt). We are interested in the responses of both wild-type and mutant to treatment. We are also interested in the differences in response between genotypes, which is captured by the interaction term in linear models.
First, we construct example data. Note that we changed sample names from “sample1” to “Wt_Ctrl_1”, according to the two factors.
dds <- makeExampleDESeqDataSet(n=10000,m=12)
dds$condition <- factor( c( rep("Ctrl",6), rep("Trt",6) ) )
dds$genotype <- factor(rep(rep(c("WT","MU"),each=3),2))
colnames(dds) <- paste(as.character( dds$genotype),as.character( dds$condition),rownames(colData(dds)),  sep="_"  )
colnames(dds) = gsub("sample","",colnames(dds))
kable(assay(dds)[1:5,])
WT_Ctrl_1 WT_Ctrl_2 WT_Ctrl_3 MU_Ctrl_4 MU_Ctrl_5 MU_Ctrl_6 WT_Trt_7 WT_Trt_8 WT_Trt_9 MU_Trt_10 MU_Trt_11 MU_Trt_12
gene1 81 47 135 72 81 80 76 57 52 49 64 57
gene2 70 77 94 54 54 36 51 66 57 51 47 67
gene3 16 37 8 28 4 36 14 10 7 11 40 15
gene4 2 5 1 3 9 2 1 5 0 0 14 8
gene5 0 0 1 0 5 0 0 0 0 0 0 0
kable( colData(dds))
condition genotype
WT_Ctrl_1 Ctrl WT
WT_Ctrl_2 Ctrl WT
WT_Ctrl_3 Ctrl WT
MU_Ctrl_4 Ctrl MU
MU_Ctrl_5 Ctrl MU
MU_Ctrl_6 Ctrl MU
WT_Trt_7 Trt WT
WT_Trt_8 Trt WT
WT_Trt_9 Trt WT
MU_Trt_10 Trt MU
MU_Trt_11 Trt MU
MU_Trt_12 Trt MU
Check reference levels:
dds$condition
##  [1] Ctrl Ctrl Ctrl Ctrl Ctrl Ctrl Trt  Trt  Trt  Trt  Trt  Trt
## Levels: Ctrl Trt
As you could see, “Ctrl” apeared first in the 2nd line, indicating it is the reference level for factor condition, as we can expect based on alphabetical order. This is what we want and we do not need to do anything.
dds$genotype
##  [1] WT WT WT MU MU MU WT WT WT MU MU MU
## Levels: MU WT
But “Mu” is the reference level for genotype, which is will give us results difficult to interpret. We need to change it.
dds$genotype = relevel( dds$genotype, "WT")
dds$genotype
## Levels: WT MU
Set up the model, and run DESeq2:
design(dds) <- ~ genotype + condition + genotype:condition
dds <- DESeq(dds)
resultsNames(dds)
## [1] "Intercept"               "genotype_MU_vs_WT"
## [3] "condition_Trt_vs_Ctrl"   "genotypeMU.conditionTrt"
Below, we are going to use the combination of the different results (“genotype_MU_vs_WT”, “condition_Trt_vs_Ctrl”, “genotypeMU.conditionTrt” ) to derive biologically meaningful comparisons.
##The effect of treatment in wild-type (the main effect).
res = results(dds, contrast=c("condition","Trt","Ctrl"))
ix = which.min(res$padj) # most significant
res <- res[order(res$padj),] # sort
gene275 25.38836 2.607896 0.0000588 0.2684841
gene2744 101.02954 -1.670837 0.0001099 0.2684841
gene5441 58.67469 1.758921 0.0001261 0.2684841
gene7021 74.29359 1.610853 0.0001345 0.2684841
gene7795 326.43308 -1.624323 0.0000407 0.2684841
This is for WT, treated compared with untreated. Note that WT is not mentioned, because it is the reference level. In other words, this is the difference between samples No. 7-9, compared with samples No. 1-3.
##The effect of treatment in mutant This is, by definition, the main effect plus the interaction term (the extra condition effect in genotype Mutant compared to genotype WT).
res <- results(dds, list( c("condition_Trt_vs_Ctrl","genotypeMU.conditionTrt") ))
gene5102 18.69017 4.757057 1.60e-06 0.0156912
gene7367 170.69259 1.481016 1.19e-05 0.0396827
gene8351 27.77227 3.033622 9.80e-06 0.0396827
gene8034 53.34342 -1.841023 1.62e-05 0.0403724
gene7272 92.82351 -1.414967 6.70e-05 0.1125817
Note that it has to be list( c(“condition_Trt_vs_Ctrl”,“genotypeMU.conditionTrt”) ). If list( ) is ommitted, the results would be drastically different. Perhaps only the first coefficient is used.
This measures the effect of treatment in mutant. In other words, samples No. 10-12 compared with samples No. 4-6.
Here we show the most significant gene, which is downregulated expressed in samples 10-12, than samples 4-6 , as expected.
##What is the difference between mutant and wild-type without treatment?
As Ctrl is the reference level, we can just retrieve the “genotype_MU_vs_WT”.
res = results(dds, contrast=c("genotype","MU","WT"))
gene5102 18.69017 -4.714519 0.0000020 0.0195596
gene2289 45.04711 1.763615 0.0000333 0.1218107
gene3388 122.85582 -1.529323 0.0000366 0.1218107
gene915 39.03250 2.104003 0.0001133 0.2374861
gene8351 27.77227 -2.653182 0.0001190 0.2374861
In other words, this is the samples No.4-6 compared with No. 1-3. Here we show the most significant gene.
##With treatment, what is the difference between mutant and wild-type?
res = results(dds, list( c("genotype_MU_vs_WT","genotypeMU.conditionTrt") ))
gene4127 50.03677 1.925094 0.0000091 0.0910879
gene3879 34.67704 -2.133203 0.0000283 0.0940393
gene4799 24.11059 -2.459345 0.0000197 0.0940393
gene5441 58.67469 -1.744769 0.0001418 0.2357639
gene5926 161.16737 1.524163 0.0001339 0.2357639
This gives us the difference between genotype MU and WT, under condition Trt. In other words, this is the sampless No. 10-12 compared with samples 7-9.
The different response in genotypes (interaction term)
Is the effect of treatment different across genotypes? This is the interaction term.
res = results(dds, name="genotypeMU.conditionTrt")
gene5102 18.69017 7.395771 0.0000000 0.0000341
gene5441 58.67469 -3.297673 0.0000004 0.0019104
gene8034 53.34342 -2.564030 0.0000205 0.0682558
gene8858 14.68650 4.703936 0.0000297 0.0742076
gene4799 24.11059 -2.990101 0.0001234 0.2463661
In wild-type, this gene is upregulated by treatment, while for the mutant, it is downregulated.
Example 4: Two conditionss, three genotpes with interaction terms
dds <- makeExampleDESeqDataSet(n=10000,m=18)
dds$genotype <- factor(rep(rep(c("I","II","III"),each=3),2))
colnames(dds) <- paste(rownames(colData(dds)), as.character( dds$condition), as.character( dds$genotype),sep="_"  )
colnames(dds) = gsub("sample","S",colnames(dds))
dds <- DESeq(dds)
condition genotype sizeFactor
S1_A_I A I 1.053964
S2_A_I A I 1.058935
S3_A_I A I 1.061629
S4_A_II A II 1.047347
S5_A_II A II 1.059813
S6_A_II A II 1.049639
S7_A_III A III 1.060271
S8_A_III A III 1.057331
S9_A_III A III 1.052053
S10_B_I B I 1.053989
S11_B_I B I 1.044408
S12_B_I B I 1.042376
S13_B_II B II 1.042354
S14_B_II B II 1.050094
S15_B_II B II 1.045868
S16_B_III B III 1.050772
S17_B_III B III 1.047934
S18_B_III B III 1.036983
resultsNames(dds)
## [1] "Intercept"              "genotype_II_vs_I"
## [3] "genotype_III_vs_I"      "condition_B_vs_A"
## [5] "genotypeII.conditionB"  "genotypeIII.conditionB"
The condition effect for genotype I (the main effect)
res = results(dds, contrast=c("condition","B","A"))
gene9348 48.01943 1.915941 0.0000155 0.1546441
gene928 60.03093 -1.562622 0.0001151 0.5748158
gene931 439.23135 -1.101161 0.0004187 0.6066182
gene4483 16.83153 2.957899 0.0005487 0.6066182
gene4612 29.09139 -1.742999 0.0006893 0.6066182
The condition effect for genotype III.
This is the main effect plus the interaction term (the extra condition effect in genotype III compared to genotype I).
res = results(dds, contrast=list( c("condition_B_vs_A","genotypeIII.conditionB") ))
gene316 63.666427 -1.724235 0.0000294 0.2936262
gene252 5.751827 -6.012712 0.0001418 0.2977597
gene2068 16.851863 -2.725616 0.0001422 0.2977597
gene6828 19.669827 2.840392 0.0000635 0.2977597
gene7420 85.226424 -1.510240 0.0001788 0.2977597
The condition effect for genotype II.
This is the main effect plus the interaction term (the extra condition effect in genotype II compared to genotype I).
res = results(dds, contrast=list( c("condition_B_vs_A","genotypeII.conditionB") ))
gene980 71.929692 -1.711667 0.0005822 0.648323
gene1177 109.057633 -1.281177 0.0002111 0.648323
gene5118 3.487054 -5.757413 0.0005110 0.648323
gene5570 23.786589 2.329791 0.0004286 0.648323
gene6519 94.137270 1.422193 0.0001399 0.648323
This is equivalent to using numeric vector referencing to each of the results.
[1] “Intercept” “genotype_II_vs_I” “genotype_III_vs_I”
[4] “condition_B_vs_A” “genotypeII.conditionB” “genotypeIII.conditionB”
res = results(dds, contrast= c(0,0,0,1,1,0))
The effect of III vs. II, under condition A.
This is the effect of “genotype_III_vs_I” minus “genotype_II_vs_I” ?
res = results(dds, contrast= c(0,-1,1,0,0,0))
gene7875 172.84101 1.316870 0.0000354 0.3541800
gene316 63.66643 1.399247 0.0006044 0.5256726
gene557 17.92683 -1.980097 0.0008418 0.5256726
gene1243 51.92628 -1.844387 0.0004523 0.5256726
gene1702 55.34857 -1.631481 0.0006698 0.5256726
The interaction term for condition effect in genotype III vs genotype I.
This tests if the condition effect is different in III compared to I
res = results(dds, name="genotypeIII.conditionB")
gene9348 48.019429 -2.714891 0.0000104 0.1042074
gene6251 14.477069 -4.780646 0.0000479 0.2395245
gene839 161.393935 -1.662756 0.0000886 0.2950638
gene9383 9.149222 -6.436304 0.0001560 0.3896367
gene931 439.231351 1.562204 0.0003858 0.4506833
The interaction term for condition effect in genotype III vs genotype II.
This tests if the condition effect is different in III compared to II
res = results(dds, contrast=list("genotypeIII.conditionB", "genotypeII.conditionB"))
gene5761 27.797507 4.231182 0.0000012 0.0116510
gene6598 100.143591 2.317486 0.0000214 0.1068006
gene3491 325.224707 1.942243 0.0001168 0.2853814
gene4635 8.411707 5.206116 0.0000963 0.2853814
gene5118 3.487054 8.088922 0.0002454 0.2853814
Example 5: Three conditions, three genotypes with interaction terms
For a more complex example, we now have a 3x3 factorial design. It is convenent to use a diagram to represent study design and the coefficients generated by DESeq2. Each connections in the diagram below represents a coefficient for a contrast and we can use the combination of these to define desired contrasts by travelling through the graph/network.
dds$condition <-factor(rep(c("A","B","C"), 6)  )
colnames(dds) <- paste(as.character( dds$genotype), as.character( dds$condition),rownames(colData(dds)), sep="_"  )
dds <- DESeq(dds)
I_A_1 A I 1.055853
I_B_2 B I 1.037228
I_C_3 C I 1.048146
II_A_4 A II 1.048901
II_B_5 B II 1.062858
II_C_6 C II 1.036711
III_A_7 A III 1.052625
III_B_8 B III 1.033361
III_C_9 C III 1.040028
I_A_10 A I 1.054525
I_B_11 B I 1.045331
I_C_12 C I 1.036150
II_A_13 A II 1.052502
II_B_14 B II 1.047103
II_C_15 C II 1.063802
III_A_16 A III 1.053762
III_B_17 B III 1.041255
III_C_18 C III 1.048660
resultsNames(dds)
## [5] "condition_C_vs_A"       "genotypeII.conditionB"
## [7] "genotypeIII.conditionB" "genotypeII.conditionC"
## [9] "genotypeIII.conditionC"
To derive desired contrasts, we can travel on the network of factor levels, using the given 9 coefficients as bridges.For example, we are interested in the difference between genotpes III vs. II, under condition C. This is not readily available. But we can travel from C to III, then III to I, I to II, and then II to C. Namely the path is C–III–I–II–C. In terms of coefficients: (III-I) - (II-I) + III.C - II.C= “genotype_III_vs_I” - “genotype_II_vs_I” + “genotypeIII.conditionC” - “genotypeII.conditionC” For such a complex contrast, we can use the numerical combination using a vector: c(0,-1,1,0,0,0,0,-1,1 ) These numbers are applied to the coefficients in the resultsNames. To double check we order them:
cbind(resultsNames(dds),c(0,-1,1,0,0,0,0,-1,1 ) )
##       [,1]                     [,2]
##  [1,] "Intercept"              "0"
##  [2,] "genotype_II_vs_I"       "-1"
##  [3,] "genotype_III_vs_I"      "1"
##  [4,] "condition_B_vs_A"       "0"
##  [5,] "condition_C_vs_A"       "0"
##  [6,] "genotypeII.conditionB"  "0"
##  [7,] "genotypeIII.conditionB" "0"
##  [8,] "genotypeII.conditionC"  "-1"
##  [9,] "genotypeIII.conditionC" "1"
Now we can extract the contrast.
The effect of III vs. II, under condition C.
res = results(dds, contrast= c(0,-1,1,0,0,0,0,0,1 ))
gene793 50.368566 3.737810 3.36e-05 0.1460573
gene1161 827.243573 1.844200 4.39e-05 0.1460573
gene3314 23.430794 4.580687 1.57e-05 0.1460573
gene4445 51.054925 -3.096770 6.96e-05 0.1736784
gene1555 5.073803 10.771498 9.70e-05 0.1937244
How about many factors, each with many levels? It’s going to become increasingly complex. Drawing a network graph like the one above can help you find the right combination.
Please let me know if you have any comment.
comments powered by Disqus
